I've managed to buy the 2 bearings for the transmission shaft (23220MA0000) and the transmission main shaft (23210435730).
Does anyone have experience of replacing these?
I wondered if a bearing puller would remove both, but my main concern is the collar on the transmission shaft.
If I heat the collar first, would the bearing removal tool pull both the bearing and collar off together?
Is there any way of getting a new collar?
transmission shaft + transmission main shaft
