PISTON & REBORE advice
baldock
Beitrag von baldock »
Does anyone know the upper and lower limits of diameter for each of the 4 stock size pistons?
Is there a marking somewhere on the piston to show what size it is?
Re: PISTON & REBORE advice
According repair handbook "Bucheli" Chapter 2.1 the diameter of the standart piston should be:
88,97 - 88,99 mm (10 mm below top of piston).
The limit is: 88,88 mm.
The oversized piston have stamped on top: 0,25 or 0,50 or 0,75 or 1,00 and "IN" for intake side.
The serial piston has just the "IN".
If you need more data search for the repair manual from our italian friends: "WHB_Honda_XR_Kapitel07 Kolben Zylinder.pdf"
baldock
thank you Kristian.
Do you have a link for the repair manual as nothing comes up for me on google?
10mm below top of piston? That is NEVER the right point to measure the diameter of a piston. Another mistake in Bucheli?
Cheers,
baldock
I'm new to this, where would you measure it, the pin?
Hello Baldock,
Here are the measurements for the piston and the piston pin. Most right, the Service Limit.
Also where to measure it.
The next sizes are +0.25 / +0.50 / +0.75
Best regards
baldock
the piston only has 'IN' so I assume is standard size.
Piston measures:
88.62mm (TOP), 89.01mm (MIDDLE), 88.99mm (BOTTOM)
cylinder bore measures:
89.29mm (TOP), 89.30mm (MIDDLE), 89.32mm (BOTTOM)
baldock
would the above measurements be ok to just hone the cylinder and put my NOS standard piston/rings in?
baldock hat geschrieben: 23. Juni 2021, 00:16
Piston measures:
So if I calculate right: the piston has ~0.31mm clearance in the bore, but should have a max. of about 0.10mm. (see the line next to last "piston to bore-clearance")
As you see: Honing wouldn's solve the Problem.. :lol:
You will need a new piston two sizes over. But I would recommend to visit a qualified motor-repair-shop and ask there for measuring cylinder and piston.
Cheers,
baldock hat geschrieben: 23. Juni 2021, 00:16 the piston only has 'IN' so I assume is standard size.
Piston measures:
Fascinating!
To me it looks like your cylinder was honed for the first oversize and the original piston was installed. A mistake in the reassembly?
You should hear that much play, it's called piston tilt.
I agree with Hans, ask a good engine repair shop what to do.
Cheers
baldock
thanks :top:
baldock
I took the cylinder and old standard piston, a new +.25 piston and a new +.5 piston to the machine shop.
The +.25 just dropped straight through the bore with too much slop.
Engineer felt a slight groove in bore then said they'll rebore/hone for the .5 and see if the groove is gone.
If not, I can't rebore to .75 as I don't have a piston that size.
fingers crossed
"a slight groove in bore" That's new for us.
Where does it come from? Do you have a picture?
To take the next size (+0,50) is okay.
Good luck for rebore/hone
Cheers
baldock
is there a place you guys get your pistons/rings from in case I need to get a +.75?
