I need advice on removing dowel pin from rocker arm shaft
baldock
Beitrag von baldock »
the dowel pins (91101429000) are stuck in the rocker arm shafts (14451428000).
I've tried using grips to remove them, but they won't pull out.
has anyone got any tips on how they do this?
Re: I need advice on removing dowel pin from rocker arm shaft
search under: http://www.xl500.de/tipps/topseite/schraubertipps.htm > Spezialtipps > Kipphebelstifte
regards Peter
another hint is at this thread (7th input) using a vise (Schraubstock)
viewtopic.php?f=2&t=6865
good luck
Yep,
patience until you come up with the right idea. A vise can be a powerful tool indeed.
Good Luck!
baldock
thanks guys :top:
baldock
they both came out using the vice method. I heard the initial 'crack' and then by twisting left/right as I pulled upwards. :top:
Right way 8)
