Clutch lock nut - 90235429000
baldock
Beitrag von baldock »
Hi,
is there a clutch lock nut from another Honda bike that will fit?
CMSL lists them for € 5.50 (90235429000), but they haven't got any in stock at the moment.
I took a gamble and bought an 18mm one off ebay for a HONDA CB500X 2013 (90236-MGZ-J00), but the socket size is much larger and I'm not sure if it will fit, or even cause other problems if it does.
Re: Clutch lock nut - 90235429000
Does anyone have the exact dimensions of this nut? It is a nut with M18 fine thread, 24mm spanner size and a small rim for securing. Which fine thread?
Hat den jemand die exakte Maße dieser Mutter. Es ist eine Mutter mit M18 Feingewinde, 24mm Schlüsselweite und einem kleinem Rand zum Sichern. Welches Feingewinde? Ich habe gerade solch eine Mutter nicht zur Hand.
Viele Grüße / Cheers
Hi,
90236-MN8-000 is identical to 90235-429-000 and fits.
thread size is MF 18x1mm
greetings Peter
baldock
thanks guys.
90236-MN8-000 seems to be unavailable too but at least its another to look for on ebay
Here are the dimensions of the available coupling nuts.
90235-HB3-000
Wrench size: 24
height hexago: 7
height overall: 11
90236-HA0-000
Wrench size: 27
height hexagon: 6
height overall: 9
90236-HN5-M00
Wrench size:27
height hexagon: 6.5
height overall: 9
best regards Peter
