Seite 1 von 1
Your favorite torque
Verfasst: 27. Februar 2016, 18:39
von HappySwed
Soon the time to assemble the cylinder head and valve cover. As a motor rookie I am very uncertain. When I look at my Haynes I can find different figures for torque.
I would appreciate your experience.
Greetings from Sweden.
Re: Your favorite torque
Verfasst: 27. Februar 2016, 19:39
von Gunnar_HH
That's right, there are 6mm and 7mm and camsproket. Take a look to the picture.
Verfasst: 28. Februar 2016, 15:51
von Gunnar_HH
Hello Happyswed,
you did asked us to our experience.
The M6 thread must withstand exactly 10Nm. Not more not less. When the threads run away you need thread-inserts from "HeliCoil" or "TimeSert" or "Ensat". The aluminum cylinder head is very soft.
Best regards
Thread=Gewinde
Verfasst: 3. März 2016, 14:20
von HappySwed
Many thanks for your info!
I have now made the first test with the 4 off M6 bolt to the Valve adjuster lid. I use 10 Nm and it was OK.
I still have problem with a broken M6 bolt left in the cylinder head. I have drilled a 4 mm hole into the bolt. One person recommended me to use a left-hand drill. Any experience?
Also in the cylinder head there is a broken Helicoil insert. Same person recommended me to drill a bigger hole, for M8 or M10 if it was possible. Then made an "insert" from a bolt and made a M6 tread in it. Good idea?
Do you use any Loctite or similare?
Thanks in advance!
Verfasst: 3. März 2016, 19:21
von Gunnar_HH
Very interesting. Send us a photo. Max. size largest side 760 px.
Left-hand-drill can help you, but you have to heat up the section before trying.
And the dont break-through the drill-out-tool (worst case).
Using a bigger insert is also a good idea,but there must be enough material (flesh) around.
No Loctite for screws, maybe for the inserts.
Hej då
Verfasst: 3. März 2016, 19:27
von Gunnar_HH
and greetings to Lundgrens. Best fishing shop, ever.
