Has anyone added wiring for a sat nav?
baldock
Beitrag von baldock »
The wiring harness will be added soon and I guess this would be a good time to fit a USB socket for a sat nav.
Maybe something like this, that has an ON/OFF switch to stop the battery from draining if the bike isn't used for a while.....
https://www.ebay.co.uk/itm/324575403140 ... 1438.l2649
Do you run the positive from a fused wire directly off the battery or by tapping into a connector behind the front light (eg. horn, lights, indicators etc.) ???
Re: Has anyone added wiring for a sat nav?
Hi Baldock,
I have my USB-Charger directly from the battery. It also has a on/off switch. The connector is placed at the left side cover.
To connect this at the wiring for lights its not so clever, because of it will online be on when the the motor is running. Maybe the cable for the horn, this has power, when ignition is on.
Greetings Gunnar
