xl 500 s flap valve
for all questions and answers in english
kurapyöräilijä
xl 500 s flap valve
Beitrag von kurapyöräilijä »
flap valve 4 stroke motor ??
wooki
Beitrag von wooki »
never seen before, makes no sense, but looks original .....
Hello!
It´s an XR 500 engine, Motornumber PE 01 E ........
See here:
Dies und Das : 11th november 2005
Wo sind die Leute, die immer gleich alle Nummern parat haben?
Ein XL 500 Motor mit der Nummer PE 01 E - 530....
Wo kommt der her bzw. welches Baujahr ist das???
Ich kann die Nummer nicht finden / zuordnen.
http://xl500.de/phpBB2/viewtopic.php?t= ... highlight=
kurapyöräilijä
Yes Motornumber is PE01E-5202XXX and frame number is PD013204XXX
kurapyöräilijä
crome kickstarter and brake bedal, original???
Hello kurapy!
The frame, kickstarter and brake-pedal are original XL 500 "S".
The XR-engine is original not mounted in there, the motornumber has to be: PD 01.......
Red-Rocket
Beitrag von Red-Rocket »
:idea:
The "Flap Valve" is called a Reed Valve in English.
It was original in the XR500R to produce more torque at low RPM.
It was often removed by XR riders which gave the bike some more power at high RPM.
Enjoy your Hybrid bike!
Derek
One cylinder is enough.
The reed-valve is notorious for braking and spitting it parts into the engine. Not to funny. A lot of drivers tended to remove valve as a precaution. Particularly because it is said that the valve doesn't work very effectfully.
But it is a very rare part!
Creetinks,
