transformation of XL500S 6Volt electrics to 12Volt
for all questions and answers in english
Georgios
Beitrag von Georgios »
Hello,
I would like to ask what the methods are to transform the 6Volt electrics of an XL500S to !2Volts.
Thanks for any help.
Georgios
torsten_bonn
Lights
Beitrag von torsten_bonn »
Hey!
Question: do you want to change it, because of the power of the lighting at night?
If so, I would first try one of these special H4-lamps you can buy for 6V-XL's.
Yesterday night I drove with a member, who had this special lamp in his XL S.
And it was much brighter than my 12V-original lamp :eek:
Best wishes
Georgios
good strong turn signals
I have put a halogen lamp, it gives better light than the original but certainly not as much as a 12V standard, like the one from my KLR650 for instance.
But the main reason I would like a 12Volt system is that I want functioning turn signals. The 6Volt turn signals are pathetic.
torsten_bonn
6V -> 12V
Ok, I see now.
I have searched in the forum; there are several themes about that; but of course all in german.
Some guys have changed the complete electric from 6 to 12V.
But you have to change really every single electrical part; including cable wire...
Sorry, can't translate these themes, because of my bad technical english.
You shoud ask a local german member in your area, when you meet them.
Best wishes
Hy Georgios,
If you want working turn signals then switch to an electronic relay and clean all contacts by scraping. That´s cheap and works...
If you´re in Athens, you should be able to locate a Bosch or Hella dealer that stores those.
To convert to 12 V, you need a generator, cdi, voltage limiter (light circuit) and regulator/rectifier for the battery circuit.
Just add it up, you´ll see what´s cheaper in an instance ;)
Have fun,
Hy Georgios!
There`s another solution to get functioning turn signals.
Mount 12 Volt LED - Blinker, z.B. from
http://www.louis.de/ ,Katalog-Seite 613
powered by DC- Spannungswandler, z.B. from
http://www1.conrad.de/ , search function.
And following drivers will need sunglasses :D
The turn signal relay can be fitted by yourself, only 6 parts.
If you want the plan, send me your E-Mail-Adress through pn.
best regards
Heinz
Georgios
Would a 12 Volt LED - Blinker work on a 6Volt system as hbmjka suggested? Do you know of any european on line shop that has electronic relay for 6Volt systems? It would be much easier than searching around Athens to find it.
@georgios
You`ve got a pn. :idee:
