Honda xl 500r
for all questions and answers in english
danijel044
Honda xl 500r
Beitrag von danijel044 »
Hello . I have Honda xl 500r, 1983. Can somebody explain starting procedure. I have heard that she can kick you when you are starting so I want know how to awoid that? Thanks
Re: Honda xl 500r
danijel044 hat geschrieben:Hello . I have Honda xl 500r, 1983. Can somebody explain starting procedure. I have heard that she can kick you when you are starting so I want know how to awoid that? Thanks
Hello!
Look at this Threads! I have translate with Bablefish in english! I hope it`s ok for you, or use the search funktion! :)
ankicken
ankicken
Schraubertipps
hillclimber
Beitrag von hillclimber »
Hi,
I hope my English is better than the babelfish translation....
To avoid the kick back there are two important things: Do not touch the throttle handle at all while starting. Kick the starter down to the bottom, if you hesitate and stop somewhere inbetween, she can kick back. That is my experience. The starting proceedure depends on the decompression you use - there is a manual and an automatic decompression mechanism, I use only the manual one. First you have to find the top dead center, that's the point where you feel a high resistance. To overcome you use the decompression now and continue only a little until you feel the next point of reseistance which you also overcome but this time without the decompresseion lever, you let the kick start back to the top and kick with all the power you have until the very bottom end.
I am not a technician - so please correct me if there is a mistake.
Have fun - Cheers Gundi
www.hillclimbing.net
PD02 Frieda
NC27 = CB1
Beta Alp 4T
danijel044
Ok,thanks a lot. :zustimm:
