( ich bin englaender und habe bei der uebersetzung ins deutsche bestimmt fehler gemacht, daher auch noch mal die englische version) DANKE
hello all
the girlfriend has just bought an 82 XL500 that runs well
but the clutch will need some work
when pulling the leaver in its very stiff but the cable routing is fine and moves freely on its own
hence the problem is inside the engine so im thinking it could be a bent clutch push rod that is the problem
so how easy is it to pull the side cover off as it has some sort of automatic decompressed connected to the kick-starter any help please is most welcome
Del
